08-22-2008 07:45 AM
08-22-2008 07:57 AM
08-22-2008 07:59 AM
08-22-2008 08:28 AM
08-22-2008 08:34 AM
08-22-2008 08:36 AM
You really need to learn how to ask correct questions. You will not be penalized for using more than a dozen words. Reading voltages and currents (which a scope does not do), requires some sort of hardware. What do you have? Have you looked at the shipping examples? There are examples that simulate a scope and examples that use an NI DAQ card to acquire a signal. There are examples on the Developer Zone such as this one.
08-22-2008 08:50 AM - edited 08-22-2008 08:56 AM
There u go , a VI that measure voltage from osciscope , it is only taken from 1 channel now 🙂
Open the VI , select ur channel (from ur device) , and then run it
08-22-2008 09:13 AM - edited 08-22-2008 09:15 AM
kmous, when posting examples please don't disable the Abort button. People sometimes need to use that button. Unless the example is to explicitly provide an example of a window appearance, leave the appearance set to "default".
Also, with respect to your (ur) VI:
08-22-2008 09:19 AM
He said read like osc so i thought he wants a VI that act like an Osc , we will see when he gets back to us 🙂
Here is another Version that measure 1 channel 1 sample
08-22-2008 09:19 AM
