Images in Vision Assistant are distorted from a FLIR thermo camera
I'm trying to view my FLIR A315 in Vision Assistant and MAX (not at the same time), but the images keep coming up distorted.  I can tell there is data being sent, because the histogram shows info and if I mess around with the Attributes I can clear the image up some but it never get as clear as FLIR software.  I'm sure I'm missing something simple but this post seemed a good place to start.  Thanks
(2,290 Views)
Hi Recordpro,
It could be your pixel format settings. Open Measurement and Automation Explorer and select you camera. Then click the Acquisition Attributes tab at the bottom and change your pixel format. If that does not work here are some good documents on GigE cameras.
Acquiring from GigE Vision Cameras with Vision Acquisition Software - Part I
http://www.ni.com/white-paper/5651/en
Acquiring from GigE Vision Cameras with Vision Acquisition Software - Part II
http://www.ni.com/white-paper/5750/en
Troubleshooting GigE Vision Cameras
http://www.ni.com/white-paper/5846/en
Tim O
(2,268 Views)
