03-18-2019 12:58 PM
I am currently working on a project where I have to create a Temperature and Pressure VI on LabVIEW using the Ricardo E6 Engine
Im reliably new too LabVIEW and I am just wondering if there is anyone who could help me with this ?
the equipment that have is;
-Kistler Type 7061B Piezoelectric pressure transducer
-K type thermocouple
-NI cDAQ-9178
-NI 9215 card for the pressure measurement
-Bruel & Kjaer Charge Amplifier type 2635
If anyone could give me some guidance this would be much appreciated.
Attached is what I have created so far, I have to sync the encoder in order to get the pressure data at TDC
03-19-2019 07:02 AM
Hi Matthew,
Here are some steps we can try:
Best,
Rob
03-19-2019 08:32 AM
+1 for what RobGeografo wrote.
Please allow me additional comments in a different area:
- From the project overview you gave in your posting I don't get what exactly your final application shall look like. Do you need to acquire temperature and pressure in parallel? Do they need to by in sync?
- Your current code is a one-shot VI. Starting it it acquires data once, then stops. Maybe this is what you need, maybe not. Give us a hint (-:
- Your pressure sensor is connected to the NI-9215 DSA module. Where do you plan to connect the thermocouple?
- Your pressure task looks quite good. Please note that the 9215 can do 100kS/s. You have currently set the sample clock input to 200kHz. Not a problem, as you use your encoder output as sample clock, however this might be an indication that you expect like 200kHz as the encoder pulse frequency. Be aware.
