Include other third party installers in my program installer
hello
The application I'm using needs to work with a lot of third party devices and drivers which have to be installed in the same time.
do you know if it's possible to include every installer with the one I'm creating for my application?
thanks in advance
Pierre FCentum TNS, Grenoble
Certified LabVIEW Associated Developer
(2,571 Views)
This isn't quite as trivial as one would hope.
Take a look at this thread, and though old you could give kudos to this idea in hopes we'll eventually get it 🙂
(2,567 Views)
I use Inno setup and ISTool to make an installer of installers, with one of those installers being the one generated by NI's application builder.
https://forums.ni.com/t5/LabVIEW/LabVIEW-installer-with-Inno-setup/m-p/3688270#M1037104
https://forums.ni.com/t5/LabVIEW/Using-Inno-Setup-with-LV/m-p/3637595#M1021422
A solution provided by NI would be preferred but this works well enough.
(2,555 Views)
owenM, the kudos is sent 😉
I'm trying Innosetup. thanks for your advises
(2,546 Views)
