10-06-2017 02:02 PM
I would like to know if I can trigger a LabVIEW VI to start running after receiving a current signal. I have a NI 9208 current input module connected to a cRio-9074. I don't know what to add to my VI to make this work. Could someone help me with this, please? Thank you for your help!
Best Regards,
Daniel
10-06-2017 02:11 PM
Hi Daniel,
Sounds like those 3 simple steps:
- read in signal in a loop
- end loop when "trigger condition" is met
- run your other VI…
Which of these is a problem to you?
10-06-2017 03:19 PM
Thank you for your prompt response. My problem is that I don't know where to find these commands (I don't know the name of the function that I would pick from the functions palette). Could you help me with this? Thanks!
10-07-2017 02:22 AM
Hi Daniel,
in this case I suggest to take the free beginner tutorials to learn LabVIEW and to handle the cRIO programming!
All you need to start is a (while) loop with a ScanEngine IONode inside to read your signal…
