Instrument IO assistant can not open
I can not open instrument io assistant in labview.it said measurement and aotomation explorer or instrument io assistant is not installed normally.But I think I have installed all the drivers and programs.I can see the divice and GPIB in NI MAX.
The vi program can run in another computer(windows 7 Labview2014),The new computer is windows 11 Labview2018
(688 Views)
I think I found the problem.but I can't solve it
from
Solved: Again : I/O Assistant not installed correctly. - NI Community
martjin's answer.I check my vi.lib folder,there is not InstrIOAsst folder.I think it is the reason.
But NI pakage manager shows I had already installed NI IIOA,and I uninstalled it and reinstalled it  or repaired it,it doesn't work
Is the version not support or something wrong?
(658 Views)
I think the drivers NI VISA and NI 488 is successfully installed. Because I can control the device by another program.But I just can’t install instrument IO assistant successfully.
The NI package manager only have IIOA 20.0 . Is IIOA 20.0 support windows11? It doesn’t shows windows11 on the support list in the website
(625 Views)
No, windows 11 is not supported.
Santhosh
Soliton Technologies
(608 Views)
Thank you for your answer.
I changed my computer.now it is windows10.but the problem still remains.
(550 Views)
