Intensity Map: Can I overlay a asterix or a symbol over a cloud of data points ?
All
I have an intensity map where I display the clouds based on a spectrum. I'd like to display an "asterix" or any kind of symbol on the middle of the cloud or anywere on the cloud based on some calculations that I do. I've seen people do it on LabWINDOWS, I am not very sure how to achieve this in Labview. Any suggestions/help ? Please see attachment. That must have the cloud, but without the symbol.
Kudos are the best way to say thanks 🙂
Message 1 of 10
(3,666 Views)
You could create a cursor on the intensity graph and set its position programatically with a Cursor.Position property node.
Message 2 of 10
(3,658 Views)
I forgot to mention one thing. The number of clouds is in the form of a 13 x 13 matrix. So I would require one symbol for every cloud. Is there an elegant way other than using 169 cursors ?
Message 3 of 10
(3,655 Views)
What?  You don't want 169 cursors?
I do know that LV8 added annotations and their properties are an array of clusters.  But I have not played with it enough to figure out an elegant way to do what you ask.  I feel like it should be possible, but am uncertain of the details.
Message 4 of 10
(3,650 Views)
"Any suggestions/help ? "
Suggestion only! No time to devlop example.
Invoke Node >>> Get image
Stick that in a picture control.
Insert as many symbols as you want.
Ben
Message 5 of 10
(3,642 Views)
Another simple method is to overlay a transparent (background) array over the intensity map the size and dimensions of this grid can be programatically set: ie 13x13 where the width and height of each cell is uniform), make this an array of strings and when you write to a cell you will get the overlayed charachers such as *.  There is a performance hit when you overlay controls but PC are fast so unless you want to do this with video imagery it should not be a big problem.  The Picture control does provide your most elegant solution but can be a little tricky to calculate possition (width, height, top, right bottom, left, origin .... why so many conventions?).
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 6 of 10
(3,639 Views)
I do not know if I would say it was elegant.
Flexible, Challenging, CPU intensive, Lacking UI functionality...
Yes!
Ben
Message 7 of 10
(3,632 Views)
Here is a very quick overlay example.  It assumes a "*" as a marker and has no logic and uses a static grid size 10x10.  I hope monitor resolution scaling will not screw things up (I grouped the controls to minimize this.
Paul
Paul Falkenstein
Message 8 of 10
(3,626 Views)
Hey, don't knock cursors.  Cursors are pretty quick.  ~45ms on my machine (LV8, XP, P4, 3.79GHz).  Coding for them is not terribly complex, either.  See attached example.
Message 9 of 10
(3,626 Views)
Jason
Your method is simple and cool. Sorry to have undermined it earlier. I've modified your code so it would work with mine. Thanks a lot.
Message 10 of 10
(3,541 Views)
