Intensity graph - How to change the grey background
Currenly I am using a Invoke Node -> Get Image to acquire an image of my intensity graph.
I want to change the grey background to a flat white or black. Is this possible?
(3,468 Views)
I believe that one of the options on the Invoke Node is 'BG Color'.  Wire a control or constant to this input.  BTW I would use a color box instead of the annoying numeric control/constant you get using the create control/constant function.
(3,460 Views)
The attached image is what I get when I changed the BG Color to black. I would like to flatten the the frame the graph is ontop of and make it black as well.
(3,453 Views)
Accepted by topic author crunch
Intensity Graphs don't have the usual 'export simplified image' method, I would suggest you paint the background frame transparent (foreground and background).  If you really like the look, you could add a 'Horizontal Smooth Box' decoration to the front panel that won't become part of the image.
(3,442 Views)
How do I go about making the FG and BG transparent?
(3,412 Views)
go to the tool pallett and in the view menu and go to the paint brush and click on the T
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(3,406 Views)
