Inverse kinematic of adjusted Scara robot
Hi LabVIEW users,
Actually i am having problem to how to use the inverse kinematic module in LabVIEW,
I have tried to adjust an example which i have found in LabVIEW library but i couldn't make the needed amended.
Now I am thinking about building a new code from A to Z but again  i feel like i lack several information.
Please check the attachment below for the example i am talking about.
Looking forward for your kindly help.
Appreciate.
Thanks.
Message 1 of 8
(3,297 Views)
Hey DALIXX,
What sorts of confusion do you have with the inverse kinematics VI? The VI uses a numeric solver to calculate joint angles, after you provide it the transform from the base to the end effector. What kind of modifications were you looking to make? The VI itself is generic in the sense that you can provide it whatever transform and joint angles you have and it will calculate the output.
For your reference, here's our help documentation on the Inverse Kinematics VI
Applications Engineering
Message 2 of 8
(3,238 Views)
Hi there,
Thanks for your kindly response.
so basically i will need to divide my problem into two sub problems, like at the first stage i will need to set up the configuration of my robotic arm as well as the forward kinematic sketch.
and for the second stage is to how to use the forward kinematic sketch to end up with the inverse right ?
i am just asking you ? if  am i right.
May you please tell me how to set the robotic configuration because there is several  blur points.
for example when i tried "initialize generic serial arm" under the kinematic parameters i need to fill up four rows  for four joints. however in my kinematic configuration i am having 3 joints and four row table  ?
I really appreciate your help.
thanks.
Message 3 of 8
(3,226 Views)
DALIXX,
I just want to clarify the questions you have an give a little bit of information given my understanding:
1. You are using the SCARA example VI, and you are wanting to know how you can use 3 joints instead of 4 joints
2. You are needing help using the forward kinematics transform to figure out the inverse kinematics equation
I suppose you could just put in a joint angle of 0 for the end effector of the SCARA arm (joint 4) since it doesn't really have any effect on the joints before it and just keep that in mind when you are calculating any end positions and trajectories
If you are having issues with actually creating the Forwards Kinematics, I would recommend taking a look at the documents linked below
Forward Kinematics VI
http://zone.ni.com/reference/en-XX/help/372983F-01/lvrobovi/forward_kinematics/
Initialize Serial Arm VI
http://zone.ni.com/reference/en-XX/help/372983F-01/lvrobovi/init_serial_arm/
Message 4 of 8
(3,213 Views)
The good news is that i have  already completed the robot configuration ( Dh-table) and the forward kinematic using matlab and then i am thinking about using the Inverse solver in robotic module.
So is that possible ? to create a Mathscript subVI for the first stage one ( robot configuration and the forward approach) and then use the LabVIEW's inverse solver ?
if you may please send for me an email to better connect dali.charfi@ieee.org
your kindly gesture it's deeply appreciated.
Thanks.
Message 5 of 8
(3,208 Views)
DALIXX,
Yes,  you can definitely use a Mathscript node to get the homogeneous transform to feed into the Inverse Kinematics VI to calculate a new position or trajectory. Also, connecting through the forums will be a better option for us, that way others that visit the forums can see our full conversations and benefit from them as well!
Message 6 of 8
(3,191 Views)
I have already posted a question about this issue cause i got an error massage.
May you please check my Vi to better understand my problem as well as to check the code that i have already did.
Please check the link below for the post
https://forums.ni.com/t5/LabVIEW/Inverse-kinematic/m-p/3802388
Your kindly gesture it's deeply appreciated.
Thanks .
Message 7 of 8
(3,183 Views)
Thanks .
Message 8 of 8
(3,176 Views)
