Is there a way to use standard Windows widgets?
Is there a way to use standard Windows widgets inside LabView (6.1)? Check boxes, form controls, et c.?
(2,455 Views)
Like the ones you find on the dialog control part of the controls palette?
(2,455 Views)
If you want to use ActiveX controls, you place an ActiveX container on the front panel, right click, choose Insert ActiveX Object and then browse for the object you want. There's several shipping examples like FamilyTree (MS TreeView object), and Ribbon, Simple Curve, and Torus that use ActiveX objects from NI.
(2,455 Views)
