Is there any way to read 2 tasks at once (with DAQmx)
Ok, I don't belive there is... but that is a problem I want to solve.
I use about 10 sensors of the same kind, but I only have 2 signal amplifiers. So I have the possibility to read from 2 channels. (Ok, I could create a task that reads from 2 channels)
I need to read from the 2 channels, but I change the sensors often so I would have to create a task for every possible combination of sensors, and I cannot do that (because the sensors should be calibrated separately in MAX).
I tried to use two DAQmx in a flat sequence structure with 2 instances, but it didn't work... as you probably know.
How to do?
EDIT:
Maybe there is a way to combine two tasks into one before connecting it to DAQmx-read?
Message Edited by Johan.svensson on 09-13-2006 01:20 AM
(2,341 Views)
See here
(2,310 Views)
