Issues installing LabVIEW
Hello all,
I'm having trouble installing LabVIEW community edition -- when I download it from the NI website, I get a .iso file. Is there a separate .exe installer I'm supposed to download? Where do I find that?
I've never had this much trouble installing software and was wondering if anyone had a solution/experienced a similar issue. Thanks in advance.
(38 Views)
A .iso file is a mountable image of a disk or DVD image.  Right-click it, choose "Mount", and Windows will create a "virtual DVD" that will open the image and let you browse it.  You should be able to find a file that suggests it is the installer (it may be named "Setup.exe").  Remember, Windows now thinks you have a CD/DVD and have mounted your .iso file -- you might also find an "Autorun.exe", which (if it were a real disk) would start executing when you "mounted" it.
(23 Views)
