JTAG Expected TDO Data
I've been learning to use the LabVIEW JTAG library from here:
http://www.ni.com/example/31157/en/
I can successfully get the ID code from my device, but I am puzzled by the expected TDO data in the Load - Unload Registers.vi. Here is an example:
I have ot create TDO and TDI data, and pass them both into the load-unload VI.
Is the TDO data just there so the VI knows how many clocks to generate?
If the answer to the above question is yes, then why can't I just tell it how much data to expect rather than actually having to create a dummy data array?
(2,959 Views)
Hi Jo-Jo,
Thanks for posting in the forums! Here is a link to a forum post that is specific to JTAG: http://forums.ni.com/t5/Components/JTAG-Digital-Waveform-Library/td-p/855097
I think you will have better luck finding an answer to your question if you post it there.
Tina K.
Applications Engineering
ni.com/support
(2,914 Views)
