LV 2009 SP1 corrupts front panel VI during 'save' operation
My best guess is that corruption happens during 'save' operation.
Steps:
1. Slightly modify vi.
2. Run it, then stop and exit with saving of changes. (Saving takes unusual big amount time and cpu/memory resources)
3. Try to open vi and get the message "LabVIEW:Generic error... error code 3:Could not load front panel."
4. Exit from LabView
5. Start LabView and got the message "The last time you ran LabVIEW, an internal error or crash occurred at loaddata.cpp, line 3070"
Tried to reinstall LabView but it didn't help.
Any advice?
Boris
Message 1 of 8
(3,333 Views)
Can you post the VI so we can see if we can duplicate the problem?
Message 2 of 8
(3,327 Views)
Sure. Please see attached.
Message 3 of 8
(3,324 Views)
Please post the un-corrupted version to see if the coruption is duplicated on other machine.
A corrupt VI is seldom useful since all it takes is a binary editor to corrupt a VI.
Ben
Message 4 of 8
(3,317 Views)
OK, Here it is.
Thanks.
Message 5 of 8
(3,315 Views)
There were a lot of things that you did not post so I skipped through them.
Did a diagram clean-up and saved without issue.
maybe you should duplicate what I did (load with sub-VI and X-Controls adn save) to see if it is still corrupted for you. If not start adding stuff back in until you find what causing the crash.
So no crash on my machine.
Ben
Message 6 of 8
(3,306 Views)
Ok, I'll try to do what you've suggested.
Thanks a lot.
Boris
Message 7 of 8
(3,297 Views)
It looks like rolling back to LabVIEW 8.6 solved the problem. Probably something bad happened during conversion of vi from 8.6 format to 9.0
Message 8 of 8
(3,260 Views)
