Hello, for some reason I cannot choose the option to save as .LVM in my SAVE TO ASCII/LVM step.
The input signal is a DBL Data output from a LabView 2011 Plugin. The data plots fine on the Data Graph... I can only save as ASCII.TXT. I want to save as .LVM because I want to include a time-stamp for every sample.
Attached is a screenshot of the step setup for the FILE EXPORT TYPE - You'll see the pull-down is gray'ed out...
Any ideas why this is disabled?
