LV2022 Q3 Install Error "NI-PCI Bridge Driver 22.5 64-bit" failed
I created an installer on LV 2022 Q3 (32-bit) for my program and get an error when trying to run installer on a Win 11 system. Error is "NI-PCI Bridge Driver 22.5 64-bit" installation failed. See attached screen capture. I recompiled the installer using "Automatically select recommended installers" under the Additional Installer section. Still get the same error. When continuing installation and performing the required reboot, I get two errors regarding MSVCP140 not found. See attached screen shots. MS Visual C++ 2013 (x86), 2015-2022 (x64) and (x86) are installed on the system.
My LV executable program will not work. Has anyone run into this problem?
(1,220 Views)
Did you create the installer using Windows 11 as well?
Installers and executables are only guaranteed to work on the operating system they are built on. Reference: Running Executables or Installers on Different Windows Versions
(1,216 Views)
Yes, compiler and installer is run on Win 11.
(1,207 Views)
Accepted by topic author cFPUser
Try installing the latest version of Visual C++ Redistributable for Visual Studio 2015. The Latest supported Visual C++ Redistributable is 14.36.32532.
Reference: NI Software Does Not Open Because of Missing msvcp140.dll
(1,201 Views)
Installing the latest MS C++ redistributable did the trick. Thanks!
(1,141 Views)
