03-26-2019 11:41 AM
Hello All:
I have a Labview HAL Project using LVOOP
Class Tree
I have tested this out in TestStand and Labview in project development mode and everything works ok. However, I am unsure of my next steps for deployment for use in Teststand as I don't want to let Teststand reference the LVProj in order to use the functions. I tried building each individual lvlib as a Packed Project Libary (PPL) but everything breaks, main issue lies with my Dynamic Dispatch Factory VI doesn't know how to reference my classes. I tried using "Get Exported File Path" on the PPLs to pass it to the factory pattern but I end up getting some error with lvclass instance cannot be referenced.
I am unsure at this point if a plug-in architecture is the the right solution, if so, I am unsure how to execute it. Hope someone can shed some light.
Mike
03-26-2019 02:26 PM - edited 03-26-2019 02:27 PM
I am currently using PPLs for my HAL for use with TestStand. What I do is make sure I keep a good directory structure. For instance, all power supply PPLs are in a specific folder. So then in my "Initialize" of my power supply library, I can do a simple "get folder" and then build the path to the class I actually want to use.
Do note that you will need A LOT of projects in order to properly use PPLs. I have a project for all of my "base classes" and then a project for each of those types for the children class so that they can properly reference the parent that is to be in a PPL.
04-05-2019 02:06 AM
Hi crossrulz:
Have you had any bugs in the past you with snippet? I tried using it but would get cases where it "finds" a lvlibp where one doesn't exist.
Thanks!
Mike
04-05-2019 05:07 AM
Figured it out, it was an issue with the project I was calling into.
