Labview 2019生成安装包是提示缺少NI Atomic PXIe Peripheral Module Driver 以及NI 488.2 Runtime Engine 以及NI Serial Runtime Engine
labview 2019生成安装包时提示缺少NI Atomic PXIe Peripheral Module Driver 以及NI 488.2 Runtime Engine 以及NI Serial Runtime Engine 。 查看NI Max中的软件安装以及runtime engine 信息,这些驱动都在。这个可以用什么办法解决
(916 Views)
after repair 488.2 ,488.2 runtime engine is OK。 NI Atomic PXIe Peripheral Module Driver  and NI Serial Runtime Engine  installer still missing
(840 Views)
Accepted by topic author MarvinLiu
uninstalled 488.2 VISA, serial component then re-install them ,the issue was solved
(772 Views)
