Labview 2020 drivers compatible with PXI 6115, 5412 & 5122?
Hi guys,
I used PXI 6115, PXI 5412 and PXI 5122 with Labview 2013 & windows 7.
After updating to Labview 2020 and windows 10 (64-bit), I just found that they do not work (no access light on hardware).
I downloaded DAQmx, FGEN, SCOPE, PXI platform version 20.0 ~21.8 (also 2023 Q3..) but they still do not work.
Could you guys tell me which version do I need to update?
I tried a lot of versions.. but I'm still suffering same problem.
(137 Views)
It looks like you are installing the compatible drivers. Are you using an MXI remote controller by any chance? If yes, it might be a more complicated issue. See MXI-Express Compatibility and Connectivity Troubleshooting Guide
(108 Views)
