01-30-2008 09:50 AM
I'm developing some new software/hardware systems for use in research laboratories. Many of the tests that are done range from very high channel count, multiple PID control, down to a simple thermocouple feedback controlling a hot plate.
The challenge is to develop a somewhat general purpose system that can do the big stuff and the small. A laboratory may contain 12 small systems or one large system. Due to cost and space constraints, it would not be possible to install 12 computers, monitors, keyboards and 12 Fieldpoint chassis.
So the idea is to go with one Fieldpoint or PC for the large system and share a Fieldpoint chassis for the small systems. For 12 stands, we may purchase 3 Fieldpoints and do 4 tests on each Fieldpoint all talking to one PC located in the lab.
Right now, I'm struggling to find the best way to architect the program to be this flexible and reusable. I may be asking too much, but I thought I would toss this out there to see if anyone may have some tips on structures, such as using events, producer/consumer, queues, notifiers, tcp/ip communication etc...
I'm leaning towards an Event structure for the UI with communication to the hardware using TCP/IP. I may even communicate TCP/IP for hardware running on the UI pc. Any thoughts would be highly appreciated. Thanks.
Here's my wish list:
User Interface (UI)
I'm looking for something that can handle 1 to 12 test stands at once, selectable at startup. The UI will be responsible for display, graphing, performing calibrations, loop tuning, starting/stopping tests, test monitoring, test setup, hardware communications, and data storage.
The UI will run on a PC. The UI can interface to hardware in three configurations: hardware running on the UI's PC (such as USB), hardware on a separate PC (using TCP/IP), and to multiple Field Point remote devices (again with TCP/IP and possibly a router).
The UI will not be critical to test operation (except if the hardware is installed on the UI's PC). In other words, I can turn off the UI's PC and the remote hardware will continue to run the test until data logging ability reaches its limit.
Hardware Interface (HI)
The hardware interface will perform all hardware I/O, PID control, test sequencing, safety shutdowns, error handling, limited local data logging, UI data for screen updates, and data transfers. The HI will do the logging real time and transfer blocks of data for storage on the UI pc.
The HI must be able to run 1 to 4 test sequences at the same time. Due to the costs of Field Point hardware, it would be too expensive for each test to have its own FieldPoint brain, so we need to share.
01-30-2008 10:20 AM
01-30-2008 11:29 AM
Thanks, Matt, for all the ideas. I've read a bit about shared variables. They seem interesting. I will look into the Node Engine, that's something I haven't heard before.
Yes, the project will be very large, but I would really like to get the software design and communication figured out first. Once I understand how things will communicate, then fillng in the blanks will not be as bad.
01-30-2008 02:13 PM
11-09-2009 11:58 PM
Thanks!
11-10-2009 06:39 AM
