Led not turn off and queue loop not end
 From attach file, I build the queue for analog read then I need to seperate control each temperature to display led (Daq assitant2,3). When I press button every loop should stop but now it's not to stop. Led is latching when the temperature is more than threshold and I press the button. Please help me. I need to clear led to normally and every loop working properly.
(2,934 Views)
@Chairat wrote:
 ... and I press the button. .
You have three buttons. Which one are you pressing? What are typical time targets?
(2,922 Views)
You should not have two loops dequeueing from the same queue.  Once on gets the data, the other loop cannot get that same data point.  Once an element is dequeued, it is gone.  You should have two queues, one for each consumer loop.
GCentral
(2,920 Views)
Could you give me some of example please, Crossrulz
(2,902 Views)
An example of what?  What is so hard about using a second queue when you already know how to use one?
GCentral
(2,886 Views)
