Losing data while writing to spreadsheet
I've been working on a VI to acquire data from two instruments and write them to a spreadsheet. For this, I wrote two sub-VIs to acquire the data -- one for a scale, and another for a conductivity and temperature meter. Independently, each sub-VI works fine; however, the conductivity meter sometimes writes a 0 value to the spreadsheet in the main VI. I thought it might have been a problem with the sub-VI, so I wrote a little section to catch and eliminate any 0 results it produces (I have it set up to collect an array of results and get the mean to reduce noise). This didn't work and every 5 or so points of data it writes NaN or a strange value. I think there's some data loss in the main VI caused by one of a couple things:
- The response time of the scale is on the order of milliseconds, but the response time of the conductivity meter only sends a signal every 5 seconds. Could this difference cause a loss in data?
- Within the main VI, the scale read sub-VI is set to run a for loop to generate the array within the main VI. On the conductivity sub-VI, I have it set up to run the for loop within the sub-VI. Would this difference cause a loss?
I've attached some photos of the block diagram to help.
Thanks for the help, guys!
Anything worth doing is worth over-doing.
LabVIEW Junkie
(2,711 Views)
So, what is the question?
(It is difficult to debug pictures. Why don't you attach some real VIs instead?)
(2,696 Views)
Sure thing!
My question is why does the main VI print odd values to the spreadsheet when the sub-VIs generate values without issue independently?
LabVIEW Junkie
(2,693 Views)
I've also attached the Scale Read sub-VI here to compare it with the conductivity sub-VI.
LabVIEW Junkie
(2,686 Views)
Accepted by topic author will.nevis
I figured it out. By running the for loop inside the sub-VI rather than in the main VI, it was losing some data as it came out (?). In any case, once I set it up similar to the Read Scale VI, everything worked fine. I think, anyway. It might not look like you guys did anything, but forcing myself to put the problems on paper helped out tremendously. Thanks!
LabVIEW Junkie
(2,682 Views)
Why are you constantly flushing the IO?
Well, in the lower loop you are doing parallel I/O on a single serial port (COM3). Most likely you get a race condition because the execution order of the two calls varies.
(2,675 Views)
Yeah, that's kind of silly. It was originally configured to take data from two different scales -- one increasing, one decreasing. Those are on different serial ports. I just switched it temporarily since our current tests only use one scale and I didn't want to re-write half the VI.
As for flushing the IO, the signals that get sent to the computer by the scale and meter are sometimes a little glitchy -- they'll occasionally read halfway through a signal, and because it comes in ASCII, it can scramble the interpreter I have written. It's just easier to make sure that I have a full string of data to work with. Are there memory benefits to constantly flushing the buffer?
LabVIEW Junkie
(2,671 Views)
