LowSpeed Mode Ni 5761
Hello to everybody!!!
I'm using the NI5761 module and I want to acquiere samples at 25Ms/s. This clip only work in three ways: Multisample, SingleSample and LowSpeed. How can I configure the last opertaion mode? I have not found any paper or pdf file with info to configure it. And furthermore I don't know where can I find a manual or something like this which describle how the SPI ports works? Because with the SPI ports you can configre the ADC registers al right? Well where can i find any document whic explain this?
Thank you very much and have a nice day!!!
(2,266 Views)
Hello flote,
To configure a FlexRIO adapter you need to add the FlexRIO board in a LV project, then expand the FlexRIO, right-click on the adapter module and select the Property option in the menu. Inside the property window you can select the Module you are using and the CLIP you want to use.
It is not necessary to use SPI lines to configure the sample Clock. There are specific inputs in the module to configure it. To know how to use these options, open the example embedded in LabVIEW “NI 5761 - Clock Select.lvproj”
In addition, you can use this link to access information about the module, all CLIPs and some getting started information:
http://www.ni.com/pdf/manuals/375509a.pdf
(2,220 Views)
See Other Thread Here --> http://forums.ni.com/t5/Discusiones-sobre-Productos-NI/LowSpeed-CLIP-NI-5761/td-p/1592460
Ben Sisney
FlexRIO V&V Engineer
(2,191 Views)
