MAX & 230400 Baud Rate Setting
When I configure a com port in MAX to operate at 230400 baud rate, I get this error message. On the same computer, using Tera Term I can configure the same port with exactly the same information and Tera Term works fine. Please I want to find out if this is bug with MAX or I am missing something. Thanks.
Message 1 of 13
(4,156 Views)
Can you configure the serial port in LabVIEW using the VISA Configure Serial Port VI with those serial settings?
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
Message 2 of 13
(4,125 Views)
Thanks for your response. Yes I can and I did but I get the same error message so I concluded that I have to get it working in MAX first.
Message 3 of 13
(4,099 Views)
Hi there,
Have you tried with a lower baud rate to see if it works? Just to test the device.
If you open the Visa test panel>> Input/Output>> set the bytes to read to 16 and click Query (you are going to write *IDN?\n to your device and you are going to recive some information about it). When you do that are you able to have some information or it gives you an error?
Regards
Message 4 of 13
(4,081 Views)
Are you sure that'as the right COM port?
Bill
CLD
(Mid-Level minion.)
Message 5 of 13
(4,073 Views)
Yes lower baud rate works fine.
I will try your recommended test and report back later today. Thanks.
Message 6 of 13
(4,026 Views)
Yes, I am using the right COM port. Same port with the same configuration works fine with Tera Term. Thanks.
Message 7 of 13
(4,024 Views)
A lower baud rate works in MAX or when you use TeraTerm (or both)?
Be aware that the advice given above assumes an IEEE 488.2 command compatible device and will return unexpected results if the device is not compatible.  What is the serial port connected to?  Also, is this a "real" COM port or a USB-to-serial adapter?
Bill
CLD
(Mid-Level minion.)
Message 8 of 13
(4,005 Views)
Sorry, the reason I asked this is because MAX is really only reporting what the serial port is telling it.
Bill
CLD
(Mid-Level minion.)
Message 9 of 13
(3,996 Views)
A lower baud rate works in LabVIEW or when you use TeraTerm (or both)?
  • Lower baud rate ( less than 128000 & 230400 ) works fine in MAX and Tera Term.
  • USB-to-serial adapter
Message 10 of 13
(3,994 Views)
