MAX31685 Interface on myRIO
Excuse me, how did you connect the max31865?
Can you help me please?
Message 21 of 29
(780 Views)
myRIO has SPI connection. You for example on the example below. The rest is explained in the posts above.
https://education.ni.com/teach/resources/73/lcd-character-display-spi-interface
Kamil
Message 22 of 29
(766 Views)
Hi you can find attached a picture of my connection between myRIO1900 and max31865.
I hope that can helps you.
Message 23 of 29
(728 Views)
I have run David15's VI (Short Read_RTDMax31865) and successfully got the correct data from the MAX31865 using a myRIO. Now I remade the VI with LINX with an Arduino Nano. It read just an increment of binary digits.
Can anyone help me with this VI?
Thanks.
Chung
Message 24 of 29
(615 Views)
Hi Chung,
if I understand you need to read the max31865 whit arduino nano.
So if you want I can share an Arduino code to do this.
Let me know if can be usefull.
ciao
David
Message 25 of 29
(605 Views)
Hi David,
Thanks for your response!
I used to use MAX31865 with an Arduino IDE. And using a custom made LabView program to read the data from the serial. This one works if I just use to read the temperature from the MAX31865. NOw I have to control a MOSFET-relay to turn on and off a heater using a PID controller, and the feedback is the temperature data from the MAX31865. To do this I using two Arduinos, one for the MAX31865, and the other for MOSFET relay. I am trying to use only one Arduino to do this job using LINX. I think if I can read the temperature data from MAX31865 using LINX, I can use LINX to control the relay.
Your Short Read_RTD_MAX31865 using a myRIO works very well. I tried to replace the myRIO SPI VIs with LINX SPI VIs. However, LINX SPI doesn't read the data properly. I think SPI VIs from the myRIO and LINX are a little different somehow. Or I did something wrong in LINX VIs. I tried various things to see if it works, but no luck so far.
I am attaching my VIs which I tried to copy your VI with the myRIO VIs. If you can take a look at it, and suggest me if anything wrong I did, it would be a great help.
Thanks.
Chung
Message 26 of 29
(592 Views)
Hi All,
I am sorry to post a wrong vi. I am attaching the one I was working on.
Chung
Message 27 of 29
(585 Views)
Hi Chung,
I am trying to read temperature data from MAX31865 using LINX on Raspberry Pi.
have you achieved to do it on Arduino?  if yes, could you please upload your .vi document?
thanks a lot
Best Wishes
Ming
Message 28 of 29
(525 Views)
Hi Ming,
No, I couldn't figure it out. I found some strange things. LINX has a read/write sub-VI. I tried to write (data) "8080" and looked at the read of the sub-VI if the data was properly sent to the MAX31865. What I saw was that the data I tried to send was "0" sometimes and "128" sometimes. I don't know what that means. I post my VI several places including Digilent, but haven't heard anything from anywhere yet.
Chung
Message 29 of 29
(512 Views)
