MEAN returns NaN?
@alhabeeb wrote:
Thanks. But my question is how to keep timing and not have NaN?
If you stubbornly want to keep your existing timing (not recommended!), just place the upper code in a case structures and only execute it if the array size is nonzero.
Message 11 of 18
(268 Views)
Please see if this helps
Santhosh
Soliton Technologies
Message 12 of 18
(260 Views)
Hi, I put 100 sample per channel, and I have the same issue NaN!
Message 13 of 18
(243 Views)
Why not put an indicator on the received 2D array and see what it looks like.
We cannot really tell how things are connected from a picture, so please attach your VI.
(I have no idee why you now think it is a good idea to pollute your diagram with local variables. That stop button should be latch action and wired inside the loop. Writing a control to a local variable of itself is just plain silly! I think you need to start with some basic tutorials. And please (please!!!!) resize your index array to the required number of outputs).
Message 14 of 18
(236 Views)
What everyone is saying is to wire a fixed number to the DAQmx read VI instead of default, ideally 1/10 th of the sample rate.
Santhosh
Message 15 of 18
(235 Views)
I got it Thanks all.
Message 16 of 18
(176 Views)
Hi, I attached my VI. I have another two while loops not included yet, so I need one stop button to control all the three while loops.
Thx
Message 17 of 18
(173 Views)
Reference this KB: Stopping Parallel While Loops in LabVIEW with One Stop Button
Generally, please start a new topic when you have a new question (after you have researched your new question).
Doug
NI Sound and Vibration
Message 18 of 18
(151 Views)
