MODBUS Comms with Micromotion MVD Sensor
Hello
Sorry, only just recieved your post.
Did you manage to get a routine to work? The one I posted in this thread was used in the end for the project and worked fine, it might have required a few mods, I can't remember, but if you still need some ideas let me know and I will try to help.
Jack
Labview Version 8.5
Labview Version 8.6
Labview Version 2014
Message 11 of 14
(1,847 Views)
This is an update in case anyone stumbles across this post. It deals with occasional data loss when communicating with a Micro Motion (Emerson) Coriolis flow meters.
The Modus register to actual measurement conversion VI “5 CH MVD READ.vi ‏26 KB” has a problem.
The problem occurs when the first byte of a Modbus register is hex 0. The “Number To Hexadecimal String Function” is not programmed include a fixed width of “4”. Thus, when sent to further processing, the string only contains 7 bytes instead of the required 8 bytes. This will cause random erroneous measurements.
I have attached an updated VI “5 CH MVD READ ver 2.vi ‏26 KB”; it will also work on a 1700 transmitter.
Message 12 of 14
(1,242 Views)
Correction #1:
The problem occurs when the first 4 bits of a Modbus register sent by the Micro Motion transmitter is hex 0. The “Number To Hexadecimal String Function” is not programmed to include a fixed width of “4”. Thus when inverted and sent for further processing, the string only contains 3 -1/2 bytes instead of the required 4 bytes. This will cause random erroneous measurements.
Message 13 of 14
(1,230 Views)
Just come back to this after many years!
Do you have the modifed vi that you did a few years ago by any chance in LV 2014 ?
The one posted on the link is just the top level one.
John
Labview Version 8.5
Labview Version 8.6
Message 14 of 14
(627 Views)
