MODBUS RTU Floating point data 32bit
Hi the divices' name is multi-k made by kron, it is a brazilian company, I think you don't know the company.
The problem is I don't know how I use this exemple. I have the modbus library but I'm not knowing how use the master exemple.
How do I build the array of information to send to the slave? Address, function, the informations i want to read, how much register i want read and the crc.
I'm sending the document of the multimeter that say about the protocol, but i's in portuguese.
Message 11 of 15
(2,785 Views)
Message 12 of 15
(2,784 Views)
        Before developing your application, make sure your device is communicating or not with help of here.
   1.  Read the characteristics in datasheet and enter to modbus tester software in Modbus settings tab.
   2.  Enter correct Slave Device address in view data tab.
   3.  Select Holding address.
   4.  Enter Starting address 1 and length 4 and select data format as a Swapped floating.
Now your device will communicating successfully, let me know I will send you example code in LabVIEW for this same configuration.
Siva..
Sivaraj M.S
CLA
Message 13 of 15
(2,777 Views)
Do you have a Modbus ASC II testing software?
Message 14 of 15
(2,680 Views)
Below are some links regarding the NI Modbus Library. Perhaps these will be of some use.
Introduction to MODBUS
http://zone.ni.com/devzone/cda/tut/p/id/7675
NI Modbus Library for LabVIEW
http://sine.ni.com/nips/cds/view/p/lang/en/nid/201711
Read Input Registers Using the Modbus Library for LabVIEW
http://zone.ni.com/devzone/cda/epd/p/id/6153
MODBUS Library for LabVIEW
http://sine.ni.com/devzone/cda/epd/p/id/4756
Patricia B.
Message 15 of 15
(2,657 Views)
