Measurments and automation explore does not see Agilis usb connection
I have some problem with Agilis AG-UC2 Controller.
I am connected Agilis by USB cable to my PC.
This USB device isn't shown in Measurment & Automation Explorer but Windows XP can see it in device manager.
I am using LabView 8.0 but the Agilis controller is delivered with LabVIEW drivers 8.5. However They(NEWPORT) send me the first version they developed under 6.1
Could anyone help me how can I communicate NI with my usb cable?
Message 1 of 30
(4,812 Views)
With few exceptions, non-NI devices are not supposed to show up in MAX. After all, MAX is an NI product and cannot be expected to test and configure devices from other manufacturers.
What happens when you use the driver they provided? How is the driver supposed to communicate to the device (ActiveX, dll, VISA)?
Message 2 of 30
(4,802 Views)
They communicate using VISA, however when I try to use VISA handle in... there is COM 1, COM 3 and LPT1 but none of them correspond with my USB device (I checked by switch off the cable and the same Visa handle were).
Message 3 of 30
(4,797 Views)
There are a couple of ways that the USB interface could be used. One is if the interface is emulating an RS-232 port. The LabVIEW code would then be no different than a normal serial connection. The other is by using USB RAW mode. In either case, you need a driver (.inf file) from the vendor in order to load the low level windows driver. You say the USB port shows up in device manager. How does it show up there?
Message 4 of 30
(4,794 Views)
Have you tried this tutorial:
USB Instrument Control Tutorial
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 5 of 30
(4,769 Views)
when the usb is connected to PC, Device Manager see it as Newport Agilis-UC2. I have also agilis User Tool - it means that when I switch on I can controll Agilis manualy using computer
 I attached also screen with Agilis User Tools - green light means that is working but when I try to use LabVIEW drivers for example read_write.ie Visa handle cann't see this devices.
Message 6 of 30
(4,767 Views)
Not Yet but I Will do
Message 7 of 30
(4,764 Views)
Have a look at the tutorial. As Dennis mentioned, you will have to create a .inf file using the Driver Development Wizard to have MAX and LabVIEW recognize your device.
Adnan Zafar
Message 8 of 30
(4,758 Views)
If the driver uses VISA, then the vendor should be providing an inf file that uses VISA. Look at the file and see what it says or post it.
Message 9 of 30
(4,746 Views)
I haven't yet create the file .inf but I found that manager devices see also Agilis usb as a port(Newport Agilis-UC2(COM3)) and MAX see this port as ASPRL3(COM3-Newport Agilis-UC2) and now when I try run the LabVIEW programm the error is coming that VISA cannot access it. (see attached)
Message 10 of 30
(4,725 Views)
