Multiple Analog Inputs from 2 separate cards in CDaq (Voltage & Temp)
I have read a ton and learned a lot from these forums so THANK YOU for all that have contributed.  I would like to read up to 5 Analog Input Voltage readings from the NI-9205 AI cDaq card while reading multiple TC inputs via the NI-9213 Card.  I see many examples reading multiple channels of similar type through one channel.  But these will be 0-10vdc for the voltage and TC Type K input for the TC.
Thank you!
(507 Views)
The challenge with this is that the TC comes through but the voltage inputs do not.
(473 Views)
