My Scaling VI running slow
@UliB wrote:
@GOB34 wrote:
I have what I think is the correct structure for the overall VI but I am running into what I think is a basic indexing issue where I am not filling the cluster in the first for loop.
Try to change 'ChannelsAndCalibrations' constant from array to element.
Right now you have 8 indexing input tunnels and the one with the lowest number of elements controls the loop count, which is 0 from the array constant.
right on!
Doug
NI Sound and Vibration
Message 21 of 36
(241 Views)
pull the cluster out of the array
Doug
Message 22 of 36
(239 Views)
Thanks Doug - could you see my question on how to properly do this - I replied just as you were replying!
Message 23 of 36
(235 Views)
It is tough to describe as it is a finesse mouse gesture. Try selecting the cluster in the array constant. Ctrl drag the cluster out of the array.
Alternative:
Drop a new instance of your cluster typedef on the diagram and use that as the template when bundling the configuration cluster.
Doug
Message 24 of 36
(227 Views)
like this?
Message 25 of 36
(225 Views)
@GOB34 wrote:
like this?
yes
Doug
Message 26 of 36
(224 Views)
EDIT;
disregard, I had forgot to wire something!
Message 27 of 36
(204 Views)
I am running into a problem in that after I create these channels with the custom scaling, I get an error that the read has no physical channels specified.
Shouldn't the physical channels I specify when I create channels carry over to the start task via the task reference?
PID scale SubVI:
Message 28 of 36
(199 Views)
Figured it out!
Had to update my Hardware cluster with the new task info in order to send all that new configuration to the acquire VI!
Message 29 of 36
(187 Views)
Hi Altenbach -
Would you recommend changing the method of indicators?
Message 30 of 36
(93 Views)
