NI-9203 show "DAQ error message"
it's real hardware issue ? how to check it in the system?
I tried restart network drive and it can working 1~2days.
but still show this error message.
(321 Views)
Hi Winnie,
Could you please translate the error text in your image?
What is a "network drive"?
When your program works for upto 2 days before that error pops up then probably your program is buggy!?
(293 Views)
Hello GerdW
the error message is "DAQ error, please check you hardware"
restart yellow mark part can working a few day.
how to edit program to fix it.
The vendor is gone....
(286 Views)
Hi Winnie,
Now you provided some context to your problem…
So the network connection between your computer and the network-connected cDAQ isn't "longtime stable", which might have different problem sources.
  • Did you check your network?
  • Can you reach the cDAQ (by PING) when the program shows the error?
You edit any program by editing its source code: do you have access to the source code?
(281 Views)
  • Did you check your network?   yes, I check the network is working fine.
  • Can you reach the cDAQ (by PING) when the program shows the error?  yes..i tried it, still can ping when got the error message.
I don't really know the labview, how to check permission to access the source code ?
Only know how to open this window 😞
(276 Views)
Hi Winnie,
When you don't know LabVIEW (not even how to spell it correctly), then you should search for someone being able to assist you locally.
You cannot access the source code when all you got is an executable…
This isn't "LabVIEW", this is NI-MAX…
(268 Views)
Hello GerdW
Thanks for you reply!!
I will find vendor to help with this, if i can find...
Have a good day.
(261 Views)
