NI 9862 Disconnects from CDAQ Chassis
I have two NI 9862 DAQ modules connected to my CDAQ-9178. I was able to communicate to my DUT, but after an hour or so, the device loses connection with NI-MAX and won't communicate through my LabVIEW program neither. Has anyone had this issue before and if so, what was your solution?
(683 Views)
Accepted by topic author Ploop
Have you tried disabling USB selective suspend?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P7POSA0&l=en-US
Also, can you try connecting via alternate USB ports on your PC?  Or if you're using a hub can you bypass it and connect directly to your PC?
(663 Views)
