01-31-2011 02:02 PM
Dear All,
I am currently working on the MCB2300 board using the NI ARM embedded module. I was programming the board for a DC motor control. While I was running through several iteration, I landed up in the following error and I am not able to program the board since then.
The error was:
[3:01:25 PM] Status: ErrorNo JTAG Devices FoundError: Target DLL has been cancelledDebugger aborted !
Detail: [UVSC_DBG_ENTER, MSG: 0x2000, STATUS: 0x1] (1)Status: Run failed.
I am sure someone has faced this problem. How do I resolve this issue?
Sincerely,
Sai
02-01-2011 11:47 AM
Hi Sai,
It sounds like it is not finding your ULINK2. Can you see the ULINK2 in device manager? Is it showing up correctly? If it is not I would suggest restarting your computer. If it is showing up correctly I would suggest trying one of the example programs.
Please let me know the results.
