NI-DAQmx 9.3.5 Installation Error
When I tried to install NI-DAQmx 9.3.5 on Windows 10, I encountered the following error:
Please recommend me a solution to solve this error. Thank you.
Message 1 of 8
(2,414 Views)
Sounds like either you have a bad installation medium or a Software/OS incompatibility.  Is DAQmx 9.3.5 associated with LabVIEW 2009?  I believe LabVIEW 2015 is the first one to support Windows 10.  I just looked, and the first version of DAQmx compatible with Windows 10 is DAQmx 15.5.  Windows 7 is probably required for this 10-year-old version of DAQmx.
Message 2 of 8
(2,380 Views)
Yes, DAQmx 9.3.5 is associated with LabVIEW 2009. I tried to install DAQmx 9.3.5 on other Windows 10 PC and they worked. I'm not sure why I can't setup DAQmx 9.3.5 on certain Windows 10 PC. Or it's not supported on Windows 10 at all?
Message 3 of 8
(2,370 Views)
According to NI, the earliest version of DAQmx that runs on Windows 10 is 15.1.  Note that LabVIEW 2015 SP1 is also the oldest version of LabVIEW supported on Windows 10.  See this LabVIEW/Windows Compatibility Chart .
Message 4 of 8
(2,346 Views)
Thank you for the information.
Message 5 of 8
(2,318 Views)
I am going to download the NI-DAQmx 9.3.5, but unfortunately I cannot find it on the NI.com. Could you please let me know from where did you find this driver?
Message 6 of 8
(1,570 Views)
If you read the entire thread of this two-year-old Post, you will see that this is part of LabVIEW 2009.  If you have the installation media for this older version, and you have a PC with the proper version of Windows that suppo rts this 12-year-old LabVIEW Version, go ahead and install NI DAQmx from the Driver CD.
Message 7 of 8
(1,565 Views)
the NI DAQmx 9.3.5 is not compatible with windows 10.
the supported operating system for the NI DAQmx 9.3.5 are :
  • Windows 7 (32-bit and 64-bit)
  • Windows Vista Business edition (32-bit and 64-bit)
  • Windows XP, Service Pack 2 or greater
  • Windows Server 2003 R2 (32-bit)
  • Windows Server 2008 R2 (64-bitt )
=> For further installation you need to check the driver readme file to check the supported operating system + the supported hardware. the Readme file of DAQmx 9.3.5 (http://ftp.bmstu.ru/ssk/LabView/D3/Documents/nidaq_readme.html ).
thank you.
kudos 🤗
Message 8 of 8
(1,549 Views)
