06-29-2012 09:40 AM - edited 06-29-2012 09:42 AM
I have been struggling to find a solution for the past three days. I have a remote system set up and configured in MAX. I am also sure that it works since I am able to aquire and send test signals from MAX. I have also created virtual channels and DAQ-mx tasks for voltage inputs and outputs from MAX and saved the settings. Once I am in LabVIEW I am not able to see the virtual channels that I created in MAX. For some reason when I am in the DAQ Assistant, it does not show me a tab for the virtual channels that I have created.
Any help would be greatly appreciated
Thank you
Leon P
07-02-2012 04:13 PM
Hi;
Are you able to see the global virtual channels with a DAQmx Global Channel?
You can also try this if you haven’t already:
http://digital.ni.com/public.nsf/websearch/4363A9766216C40886256E930070861D?OpenDocument
07-23-2012 10:07 AM
I have the same problem (except I am reading out an SC-2345 RTD module). I can see the virtual channel for a vi created to run on the remote RT machine that the hardware is installed. But I cannot access the virtual channel from my local machine. MAX running on my local machine can however see the virtual channels on the remote machine.
Rick
07-24-2012 07:11 AM
Well
I do not have an answer to either of you. But i do have one doubt.
If i understand correctly, the virtual channels are created for a remote target. Are you trying to see the channels in DAQmx Assistant/ DAQmx virtual channel control in the RT target or on the PC?
I mean, is your vi on the remote target or on the PC?
