NI-DCPower Express has no dialog box for settings
I wanted to use this VI to set up the voltages on a PXI-4110 power supply module, but every time I add it to the block diagram there is a status bar that says "Initializing" then nothing happens when it is complete. I thought a dialog box would pop up where I can make changes. Any information on this would be greatly appreciated.
(2,213 Views)
Hello!
Could you please post which version of LabVIEW and the NI-DCPower Driver you have installed? You should be able to find this information in NI-MAX.
Levi D.
Technical Support Engineer
(2,140 Views)
LabVIEW 2017 SP1 and NI-DCPower 18.1.
(2,109 Views)
Accepted by topic author CardboardAidedDesign
It looks like this issue been documented with NI-DCPower version 18.1 and has been corrected in 18.1.1 and 18.2. Both are still compatible with LabVIEW 2017 SP1 and the PXI-4110 so I would recommend updating the driver! You can download it here:
NI-DCPower Download
https://www.ni.com/en-us/support/downloads/drivers/download.ni-dcpower.html#320888
Hope this helps.
Levi D.
(2,096 Views)
