NI PXIe-7966R and NI 5793 - High Sampling Rate
I'm new to LabVIEW and I want to use 7966 and 5793 together to generate high sampling rate (over 250MS/s) streaming signals. To start, I used the existing example RF_MIMO_7966.lvproj. When I interact with MIMO TX Streaming (Host).vi to change the sampling rate to a value beyond 250MS/s, I encounter an error, which is attached to this post, indicating that the sample rate is beyond the supported 250MS/s. Is there any way to increase this sample rate to a higher value (for instance 500MS/s)?
Thanks in advance for your assistance.
Message 1 of 1
(212 Views)
