NIMAX want open since upgrading to 8.5 LabView
Measurement & Automation Explorer 4.3 will not open or run since upgrading to LV 8.5.  MAX worked prior to upgrade.
I am running XP SP2 PRO.
Wally
(2,491 Views)
Hi Wally,
Try uninstalling NI Measurement and Automation Explorer. You can reinstall it by using installing any driver since MAX is not available as a separate download.
What is the message that you when you try to open MAX?
Warm regards,
Karunya R
(2,473 Views)
I click on the NIMAX Icon and it comes up with white blue window version 4.3.  After about 2-3 minutes it comes up with a message (Microsoft ) M&A has encountered a problem and needs to close.
EVENT LOG shows:
Faulting application nimax.exe version 4.3.0.49512 faulting module nihdvui.mxx, version 5.0.1.568, fault address 0x0001b.7b.3.
I going to do a reinstall tonight.
Wally
(2,444 Views)
