NXG plotting RMS-values of measured signals
I want to plot RMS-values of a measured signal; a 50Hz-signal with a bit distortion.
I'm stuck in the code, the graph in the gvi returns only 1 correct value of the first signal.
Anyone suggestions?
A next step will be logging the RMS-data as an TDMS for reducing the storage.
Kind regards,
Dries
(2,181 Views)
Hi Dries,
Could you first try with a simpler version of the VI to check if you are able to plot the data continuously?
It will help us to narrow down the source of the issue.
Best,
Rob
(2,128 Views)
Rob,
I made an other GVI (more simple), it seems that only the 4 first values are plotted in 1 graph.
Kind regards,
Dries
(2,115 Views)
