Need guidance in getting data from condition and while loop
Thanks for your reply. I need to calculate individual columns' average, which means individual channels' average, and those to DDT and from DDT are used to save data in .csv format. But I want to see the average of individual columns in the display...
kind regards
Hasham
Message 21 of 61
(575 Views)
Hi Hasham,
I told you more than once how to simplify your code, but you keep that Rube-Goldberg.
Again: you don't need all those ExpressVIs!
Suggestions:
  • Learn (more) LabVIEW basics before continuing to implement more features to your VI…
  • When sharing code it helps us when you would downconvert to some older LabVIEW version. Most say "LV2021 or older", I prefer LV2019.
Message 22 of 61
(555 Views)
I tried to do without Express DDTs, and it was giving one large column, and I needed rows and columns. Due to that, I used two Express DDTs VI. Without that, it was giving the one long column. If you could guide me on how I could calculate averages of individual columns from an array of data?
Kind regards
Hasham
Message 23 of 61
(525 Views)
Don't transpose the input?
Qestit Systems
Certified-LabVIEW-Developer
Message 24 of 61
(511 Views)
Thanks for your reply. Yes, I tried that option, and in return, I was getting on one row. I am getting data from 4 channels (four columns) and 200 iterations (number of rows), so it should be an array of 4 x 200. So, after using express DDTs, I am getting the required form of data in a .csv file.
If you don't mind, could you please guide me on how I could calculate the average of each column (channel) and display it?
Once again thanks for your guidance.
Kind regards
Hasham
Message 25 of 61
(499 Views)
I tried your suggestion, and it's working. If you don't, could you please tell me about the average of individual columns of array data in LabVIEW?
Kind regards
Hasham
Message 26 of 61
(484 Views)
Hi Hasham,
So you have a 2D array with several columns of data and you need the average of those columns?
Transpose the array, autoindex the rows in a FOR loop and use the mean function inside the loop…
Message 27 of 61
(479 Views)
I tried to run by implementing the guidance you provided, but it is giving the current value of the channel within a conditional loop. Then I also put the mean function out of the while loop, and it gives wrong values like 2, 1, 3, 1, 1, 1.
I also attached both approach images with this message.
Kindly guide me.
Kind regards
Hasham
Message 28 of 61
(472 Views)
Accepted by Hasham622x
Hi Hasham,
Why do you need 3 ExpressVIs when I suggested to use a FOR loop and a (simple) Mean function???
What's wrong with my suggestion?
I repeat: "Transpose the array, autoindex the rows in a FOR loop and use the mean function inside the loop…"
Message 29 of 61
(460 Views)
Sorry and I didn't introduce DDT express when I connected it with subVI. Then it is attached by default, and thanks for sharing the image.
Kind regards
Hasham
Message 30 of 61
(452 Views)
