Need guidance in synchronization
yes I tried to put all channels in one task and it is running so could you please guide how I could separate SYNC channel (ai0) from data and
I want to use the aio input channel as the SYNC channel and set ai1 to ai8 as input channels. In the data acquisition process, I want to get the peak points of all input channels with respect to the SYNC channel's peak point. I tried to use peakdetector.vi but am confused about how to use it.
Could you please guide me on this?
Message 11 of 15
(147 Views)
ai0 is also input channel,
which VI I should use for synchronization?
I am using single device NI-6255 MT
Message 12 of 15
(145 Views)
Accepted by topic author Hasham622x
Hi Hasham,
No need to post the (basically) same answer 3 times within minutes…
  • You read 9 channels.
  • You determine a peak in the first channel (aka "sync channel" aka ai0).
  • You determine peaks in all other channels (ai1 to ai8).
  • You determine the delay between the peaks of ai1…ai8 and the peak of ai0.
Did I understand your problem correctly?
What have you tried?
Where are you stuck?
How do the signals look like?
Message 13 of 15
(137 Views)
Yes, you are right. This is what I want. Consequently, I prepared code that runs ai0-ai8 channels with continuous sampling with 100 Hz frequency and 1000 samples/per channel. the issue is how I define peak level of sync channel ai0 and how i could detect peaks of other input channels w.r.t sync channel's peak.
I also attached the code with this reply.
kind regards
HA
Message 14 of 15
(111 Views)
Hi Hasham,
did you read my signature line?
Please downconvert your VI (File->Save for previous) so more people can actually open it. (I prefer LV2019.)
Message 15 of 15
(102 Views)
