04-09-2019 01:12 PM
You are missing the generate user event call, that I had put in the "Case1:Value Change" event case (see below).
Notice that I am not sure what you are trying to accomplish. I have just answered your specific questions about user events.
04-09-2019 01:21 PM - edited 04-09-2019 01:22 PM
Got it. Thanks so much. I have it working both ways now but the Generate event method is better and would allow event cases to cascade one after another.
04-09-2019 01:31 PM
Watch out for an avalanche!
Ben
04-09-2019 02:29 PM
Agree with Ben here. You have to be VERY careful when you have cascading events due to an Event case causing another event. You might be better off using a Queued Message Handler and then the event case just queues up all of the things the QMH is supposed to do.
04-09-2019 03:46 PM
What is the downside of one case triggering another?
04-10-2019 07:08 AM
It is very easy to create a circular string of Events that you cannot break (A to B to C to A, etc), along the same lines as to why we state to not let a Queued Message Handler queue up tasks for itself.
Plus, it becomes hard to follow. Case A to Case B to Case C is a lot of clicking to see the full chain. Where if you used a QMH, the single case queues up all of the tasks to be done and you have a simple high level of what is being done right there in a single case. You can dive into the QMH if you want to see more details.
04-10-2019 08:05 AM
Adding to what Tim already wrote...
Chaos
Seldom a good thing in software.
I still want to urge that the cod you want to put in each of theses events should be in sub-VI's. One for each event. When you find you need to implement some type of sequence, you string the sub-VIs together and sequence the operations using data flow. Doing it that way makes it obvious to the reader of your code (could be you someday!) what order is being implemented. After all this is LabVIEW not HPVee.
Ben
