Needed a Repeater exapmle with Labview communications
Hello all,
I am trying to transmit the received signal with NI USRP 2901. For this, I open an rx  session, then configure the signal, initiate niUSRP, and then in a loop I fetch rx data and thus build the waveform. Then I need to transmit the received signal.
First I tried to open a tx session within the rx diagram page, but this gave error saying that the session handling is not alright for Write tx data module.
how should I overcome such a problem?
regards
(2,526 Views)
Hello jebasty!
In LabVIEW Communications, there should should be a "Learning" tab at the top.  In there, there are two options, select "Examples".  When there you should select "USRP Host".  This is where you will find premade examples for the NI USRP.
I would recommend starting with the Rx or Tx example and get that to work before trying to run Rx and Tx at the same time.
I hope this helps!
Casey L.
(2,470 Views)
nevermind I just looked at the 2901 and see that is is a full duplex device
=== Engineer Ambiguously ===
(2,456 Views)
