Ni Web Server - 'Not Found The requested URL was not found on this server' after upgrading to LabView 2024
I have a LabView application that is compiled and packaged into an installer.  This application has a web service attached to it.  When building the entire package in LabView 2021 x64 everything worked fine.  After moving the exact same code into LabView 2024 x64 and re-building the exe and installer, the newly built application does not seem to be loading the web pages.  When I call the web link from a browser against the built in 2024 version installed on a target pc, all I receive is:
Not Found
The requested URL was not found on this server.
But when using the same code compiled in LabView 2021 and installed on a target PC, the web page loads just fine.  From what I can tell all the setting are matching and I am including the correct files with the installer.
Any help or direction to look would be appreciated.
M
Message 1 of 1
(913 Views)
