09-22-2010 03:10 AM
Most subVI icons are the default square shaped.
If the icon is to be designed to be a circle or a star, below is the procedure;
Although, by default, the shape of the subVI Icon is square, there are ways in which you can make your icon look a different shape. The reason that the subVI retains the square shape is because of the default black and white icon. Typically, icons that follow good LabVIEW programming style should remain square. To change your icon into something other than a square, follow these steps :
Whatever changes you make to the 16 Colors and the 256 Colors icons, the shape of your icon will remain what you selected in the Black and White icon.
NOTE: You can also just place just a dot on the Black and White icon. Now when you make changes to your 16 Color icon and the 256 Color icon, there will be no extra white space.
Now design custom VI Icons of your own !!!!!!!
<<Kudos are welcome>>
09-22-2010 03:55 AM
Good one.. But cannot be used in applications as it needs to be formal...
09-22-2010 04:06 AM
Electro Sam,
it's a good thing that you have written the nugget. You should add a post with that information for the new icon editor which was introduced with LV 2009.
And to add something:
Normally, you should not use "random" icons using transparency. You should stick to the default size of 32x32 pixels. But there are cases where smaller icons come handy. Examples would be special error handler VIs, data transformation functions and alike.
Norbert
09-22-2010 04:49 AM
09-22-2010 09:30 AM
And it's really not necessary to delete the black & white icon. It can be copied from the 16 or 256 color version.
09-22-2010 09:54 AM - edited 09-22-2010 09:57 AM
Tip:
Make sure whatever connector terminals you use on your subVI, you have a part of the icon covering the center of that connector (usually you can show the actual attachment point with an X).
Otherwise a wire could look like it is starting in empty space.
09-22-2010 10:02 AM
09-22-2010 10:02 AM
This information can also be found in the LabVIEW Help (search the Index for "icons" and then select "custom-shaped"), although there's no image in the Help, which would be more useful. There's also an example that ships with LabVIEW.
01-09-2011 10:32 AM
Thanks I think I got it now.
