07-17-2024 09:25 AM
I have an Ocean Optics USB 2000+ that I'm trying to use with LabVIEW 2018 on a Windows 11 PC. I need to get the VISA resource associated with the device, but the device isn't recognized by Ni-MAX. The spectrometer works just fine when using the Ocean View software. I've tried downloading and installing the device drivers from NI. I get and "not enough memory" error when trying to install the .inf file. Not sure what to do next. The NI device driver lists the very model I have. I don't think it's a wrong driver problem, but I suppose it could be. The device is recognized by Ocean Optics Ocean View software and works just fine, but I cannot get it recognized in LabVIEW. The install directions that were provided are attached.
Solved! Go to Solution.
07-17-2024 10:10 AM
I followed the attached directions
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019La2SAE&l=en-US
and replaced the divers that were installed by Ocean View and reported as the most appropriate with the ones provided by when I downloaded the drivers from NI.
