One time operation of a part of the VI
Hi
I am stuck with a issue in a complex program I am using!! Wish you can help me out.
I am using a Ethernet-can module and its library in LAbview for a motor control application.
The issue is, there is a de-initialise block (of the can) which deinitializes the CAN communication. In my program, I kept it as a Push button control. SO I need to push it and out to again restart my communication!!
But, I need it to be done logically i.e. the on and off should occur internally using some logic!! Is there a “one-shot” operation? Canit be done using shift registers? I am writing to you after doing a lot of work from my side!!
Waiting for a reply!
(2,305 Views)
Hi Vijay,
  You mean to say that you want to create ON and OFF using some logic using some subvi ?
Thanks and regards,
srikrishnaNF
Srikrishna
(2,299 Views)
Accepted by topic author Vijay Chand
Yeah!! Actually i could solve it 🙂
I have kept a simple counter and compared it with a constant value (100). So when the counter reaches 100 i've switched it off !!
(2,294 Views)
