06-26-2023 11:31 PM
这个PCI-1405 很老了,我安装在WIN 10 64下面 显示异常,驱动采用 2018 的 ,
06-27-2023 12:43 AM
Hi luosch,
@luosch wrote:
This PCI-1405 is very old, I installed it under WIN 10 64, the display is abnormal, the driver uses 2018,
What is the question?
When you want to use that "very old" hardware you should also use a "very old" computer with the software needed for that hardware (including the correct Windows version)...
06-27-2023 08:21 AM - edited 06-27-2023 08:23 AM
Somewhere around NI-IMAQ 19.0, NI removed support for camera interfaces other than their CameraLink devices (143x).
So you should make sure to us.e an earlier one but not to early, as it also needs to support Windows 10. And if you use a newer LabVIEW version than 2018 you are in a bit of a bind as the NI-IMAQ 18.x only installs support VIs into LabVIEW 2015 - 2018
