PCI-6601 34-pin connector
Good Day,
I would like to know if the 34-pin connector (looks like a floppy drive connection) that is connected to the top of the card can be used to output signals.  My signal out is to be connected inside the computer and this would reduce a need for a cable/hole.
Thanks a lot!
(2,660 Views)
Yes you can, you will need to route the signals. This connector is called RTSI (Real Time System Integration). Then use the names specified here when you route:
http://digital.ni.com/public.nsf/websearch/AD2D553F55A07BBF8625650D005F1F00?OpenDocument
This documents explains how to route the signals:
http://digital.ni.com/public.nsf/websearch/A441EB181C1D582C86256A4800689D6D?OpenDocument
Hope this helps, let me know if you need more help with it.
Gerardo O.
RF SW Engineering R&D
(2,643 Views)
